So what size spark plug should I get?After the head was resurfaced you now have inadequate clearance between top of piston and plug.
you end up with about .080" clearance (ground strap to piston) on the 60's I have seen. Not sure about the 65's. why not gap it and turn it over with your hand and see if the electrode is moved again. WOW, though, an iridium plug!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (did you have enough money to buy enough ammo so you could shoot your other foot too???????????????????????????????)
seeing as how you to have a crf250r, you already know all about expensive spark plugs.you end up with about .080" clearance (ground strap to piston) on the 60's I have seen. Not sure about the 65's. why not gap it and turn it over with your hand and see if the electrode is moved again. WOW, though, an iridium plug!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (did you have enough money to buy enough ammo so you could shoot your other foot too???????????????????????????????)
Ok so I went to the shop and bought a brand new spark plug. The one it came with from the factory. I put it on and gave the bike a lot of kicks and it didn't crank like before. I then tried to roll start it and got nothing. Right when I was about to give up I gave it one last good kick and it cranked! It idled and everything! However I cut it off shortly after because I saw smoke coming back from between the boot and carburetor. After I cut it off I pulled the plug and it was still exactly how it was when I bought it so I assume it was bent from the people who worked on my cylinder. Now I just need to know 2 things: why did it take so long to crank with the new plug, and why is it smoking from the carb boot?
