Ok I found out... Coolant is still somehow getting into the cylinder... How???? The head is resurfaced. Brand new gaskets. And a torqued the bolts down to factory specs with a torque wrench... I just don't understand what's going on...
Because I pulled off the radiator cap and its foaming white. Also it has hardly any power when I tried to ride it and wants to bog down.How are you sure it's burning coolant? Because you filled the rad and it dropped after you started it? It will drop a little after re assembly as the system fills
It's coming from the top gasketGet a pressure tester. Pressurize the cooling system, pull the exhaust pipe and try to see if you can tell if coolant is coming from the top of the head/ cylinder or the lower end of cylinder. Could be a base gasket or an internal crack between The coolant passages and the intake port.
I doubt it since there is only one way this head gasket will go and the pins keep it in place. Might order an OEM head gasket and give it a go. That's the only thing I can think of. When I pulled the head off it was soaked all over with coolant like before.headgasket possible out of place when you torqued it down?
Ask them exactly what they're going to take care of!Just as I thought. The head still isn't straight. I sent it back to powerseal they said they would take care of it for me!
I already got all that. I just need the head to be straight so I can stop getting coolant in the cylinderAsk them exactly what they're going to take care of!
Full top end rebuild at their cost labor inc? New piston + plug at least?
