I'm guessing that you are asking because you can't find your owners manual. My owners manual has a big section devoted to figuring your exact towing capacity. One big variable is the rear end ratio. A high ratio makes for more towing capacity. Unless you asked for it you got a low ratio rear end because it makes for better fuel economy. The next thing to know is those ratings are usually based on a half a tank of fuel and a midget behind the wheel. Subtract for every pound you add to the truck. Four jumbo sized passengers like me and that towing number can go down by 1000 pounds.
cleonard got it backwards me thinks, lower gear atio pulls better and a high gets better fuel economy due to lower rpms
Who knew you had such a nice well rounded rear end Mr. Rack?3.73 rear end Cleonard.
Same one that had the KTM tattoo right?
Anyway, all of this is good info. To make absolutely sure, call you dealer, give them the VIN and they should be able to give you your exact specs.
Yeap and I'll wave at you when I pass you buy, because you blew the turbo hose off...Just buy a power stroke F350 and you will be fine![]()
Bring it Nut job....And I will wave at you as I go by in the f450
