Look who's come to play... 54
For Immediate Release;
August 14, 2013
Paso Robles, CA
American Beta is the sole US importer of high quality Beta motorcycles. Beta motorcycles are handcrafted in Florence, Italy offering a complete range of Off Road competition, Dual Sport as well as class-leading Mototrial motorcycles.
All New RS Models for 2014 !
August 14, 2013
Paso Robles, CA
American Beta are proud to announce the details of the All-New 2014 Beta RS Dual Sport lineup.
Returning for 2014 with four engine displacements 400cc, 450cc and 520cc, the all new RS Dual Sports have been developed focusing on weight reduction, improved ergonomics and ease of handling. The engines have been improved by a series of local details aimed to improve the already excellent reputation for reliability and performance.
The final result is a bike that is one of the lightest in its class, offering the finest Dual Sport features in the industry, in addition to being the best off road performing Dual Sport on the planet.
Details of the Changes:
Engine:
- Updated silencer/spark arrestor, provides a softer exhaust note while still retaining performance.
- On the 400cc engine primary drive has been shortened to further improve engine power and torque delivery.
- New decompression system for easy start of the engine in any condition.
- Air filter newly designed to improve the power delivery of the engine especially at lower RPM.
- New filter cage with improved fit to offer a more secure mounting of the air filter.
- Air filter mounting bracket changed to make the locking of the filter even more secure.
- Cooling fan kit as standard equipment to reduce engine temps in the extreme conditions.
Chassis:
- New frame reinforced at the points of greatest stress and lightened where possible, designed to be stronger and at the same time provide a consistent weight reduction. Same frame used on the RR models.
- All new wheels including brake discs with a different profile, more rigid with 6 mounting points to the hub, made of high quality steel, they provide extremely strong braking action as well as excellent feel.
- New hubs, lighter and more rigid at the same time.
- Rims with a new profile, more resistant to stress and very light at the same time.
- All new spokes
- The above leads to a weight reduction of 1.5 kg (3.2 lbs) total between the two wheels which provides a tremendous benefit in terms of ease in changing direction, greater acceleration and more effective braking.
- New swingarm with a new shape and revised thicknesses to provide a greater rigidity, better weight distribution and reduction of the masses of 250 grams (.5 lb)
- 48mm Sachs front fork
internal parts completely renovated and .48 kg spring. This allows a better control of the hydraulic system which results in further performance on both low and high speed conditions. In addition, the rebound setting is now managed by a knob for easy adjustment without tool. (Same settings as the Off Road RR Models)
- Rear shock absorber with improved settings, 5.4 Kg spring and a larger reservoir to provide a better control of the shock's action, improved cooling and therefore better performance. In addition, the body of the shock absorber is now made of aluminumallowing a saving of weight of 300 grams (.6 lbs). (Same settings as the Off Road RR Models)
- Completely new fuel tank, redesigned to offer a better centering of gravity and allow quicker changes of direction. The area around the cap is now lower for ease of movement. Moreover its design improves the air flow from the radiators to help lower engine temperatures.
- New fuel tank cap with an external thread for easier opening and closing as well as to prevent dirt from falling into the tank.
- Seat with a new side profile and a different design. It allows greater ease of movement thanks to a narrow upper part, in addition to being lighter.
- Modified seat mounting system, improved design in the front and new fixing pins in the rear. Still a quick-release design but now a more solid fit.
- New side radiator shrouds with a design that allows for better flow and increased air circulation in the area around engine head. Their shape provides a very slim feel for an improved riding position while also allows better airflow to the engine.
- Radiator grids with an optimized shape for directing a greater air flow towards the radiators, while providing the engine improved cooling under extreme conditions of use.
- New instrumentation with an industry-first Trail Tech Voyager GPS unit as standard equipment! Features include:
GPS Speed, Distance, Compass, Altitude, Temperature, Maps
View, Organize, Edit and Share Entire Trail Systems in 3D
Designed Specifically to Meet the Needs of Off-Road Riders.
- Stiffened rear subframe in the back area for better supporting the plate support, lightened and modified to facilitate the replacement of the rear shock.
- Plate support stiffened by ribs, to enable the use of bulky and heavy license plates too.
- Air filter box modified to match the new style of the bike.
- New final gearing ratio of 15/48 to ease gear changes more suitable for off road use.
- DID o'ring chain for extreme smoothness and best quality.
- New seat cover with an added pouch for a cell phone or other route sheets.
- New RS graphics package for a stunning look.
*Prices will be announced in early September
2014 Beta RS models will be available for purchase on the BYOB (Build Your Own Beta program in early September.
2014 RS Models will arrive at dealer's showrooms in October. American Beta is the sole US importer of high quality Beta motorcycles. Beta motorcycles are handcrafted in Florence, Italy offering a complete range of Off Road competition, Dual Sport as well as class-leading Mototrial motorcycles.
