ok .. well i got my 93 rm250 ..got it in a trade... was supposed to run... but it wouldnt when i got it...i tore most of the bike apart to check bearings and brakes and everything everything seems tight... i checked the compression it was at 150...but my compression tester had a leak... so i figured thats good... suzuki doesnt specify whats good or bad..... i cleaned the carb... switched out fresh gas..lubed up everything really good... put a new plug in it...br8eg... and it fired up... ran bad... so i finally got my owners manual and realized the pilot screw was turned out over 10 turns....i adjust that... and the idle ... and then bike seems to run great... but couldnt ride it becouse of the snow... so finally the other day i get on it and kicked it for 30 mins... 2 other guys kicked on it some too.. i pulled it down the road with my truck and it fired right up.... i let it sit there and warm up and took of fianally... it screams... but about a mile down the rode it dies... ive put 3 new plugs in it and it kills them... completly... there not oil fould from what i can tell........ then i look in my book and see it requires a r4118s-8 plug... and that dude is like 20 bucks... ii ordered one just to see if that is my problem... but if there a cheaper plug i can run ... or will this 20 dollar plug last longer...
Wow that ws along post.... any out there have a 93... or any info on the plug...thanks everyone
also if anyone has any aftermartket parts cheap lemme know![Biggrin :D :D](https://www.dirtbikeaddicts.com/static/images/smilies/biggrin.gif)
