Im changing my oil in my yz 250 and I realized i only had 700ml of the 20w-50 lucus synthetic that I already put in my bike. I usually put 750-800 ml but my question is, can I put the remaining 100ml using 10w-30 royal purple synthetic?
About anything makes your gears and bearings happy. If your clutch likes it you are good to go. About the only oils that don't work in a mix are the vegetable based ones with anything else. In a transmission I don't even. Think that would matter.
You can mix them, but not just any oil works for a wet clutch set up like dirt bikes have. Oils with a high concentration of moly can affect the clutch.
If you want to get stuff like that out quick, drain, fill with gas, slosh around for a minute, drain, fill with oil, run for ten minutes through all the gears, drain and fill again, that is all that's needed. No, gas will not ruin the clutch plates if introduced for that short of time.
