I usually run spectro 80w gear oil, or clutch saver, can remember the brand just know that it's in a blue bottle. my 125 hasn't seen anything riding wise except the gear oil strictly because of shear stability.Got a new clutch for my KX100. Always used regular motor oil for the gearbox, but I've heard great things about using ATF. Wanted some second opinions before I soak my plates in ATF.
Also, it's a tusk clutch if any of you were wondering
nope, i was going to but then read up on shear/sheer (sp?) stabilityHave you ran ATF in any previous bikes?
only one I can think of is Rekluse.Am I dreaming or do I recall clutch manufactures saying to NOT run synthetics with their clutches?
My honda's maual recommends a full synthetic without moly, its not so much the oil as it is certain additives (like moly)
synthetic won't hurt your clutch, any oil with moly will.I recall EBC saying to not use synthetic also
Does anybody know what oil the manual suggests on my bike?
if maxima makes it is quality
Is that like YD saying Fox is quality, or is maxima actually quality
I run ATF every once in awhile, Most of the time i run Mobil 1 Motorcycle oil. Always soak plates in ATF.
