I know right? She is added to the list....
She told you!!!!!![]()
Sorry Sun, but every time I see the word "pussy" come up, I start![]()
So to answer your question, you cut them in the area that would give you a snug fit around the filter. You do not want them to fall off or be too tight so it squeezes to much. This is installed after the filter has been put in the bike and you leave enough so you can route it outside the air box so you can reach down and pull and it comes right out leaving you with a fresh clean filter.
Now I only used this when riding the Baja 1000 when we normally would be changing about 6+ filters during the race since it is pretty dusty down there. This process cuts that in half which saves filter changing times...
Now, back to the other threads...![]()
Remind you that this was a trick that we used in 91 and airboxes have changed some. I would need to look at the honda box and see how this could be accomplished the easiest.Cool! So I dont even have to worry about it being over the bolt that holds the filter on huh. If the filter fits so damn tight on there, which my honda does and the damn thing is a bitch to press down on and screw in, then how the heck will it pull out that easy? It just does because it is thin and maybe has a little filter grease on it by then? I thnk Im going to try this.
Thanks for the info CDA, now back to yourpreferred thread!
Someone has to remind you guys now and then that this site IS about dirt bikes get you all back on topic now and then! It doesnt last long though, it goes right back to gay male bonding and hot chicks. That's cool for the most part. I just read and laugh. Or dont read at all
Im on the list nowDoes this mean I move to the head of the line?
sounds like a tampondont lose the string
As far as the list, you can be moved right in front of me, so I can keep my eye on your err uh I mean you...![]()
You can try to keep an eye on it...BUTT I may turn around!
Room? I know a long deserted canyon.
Not sure if I'm reading this right, but it does get pinched between the filter and airbox?
Get a ROOM
No it does not get pinched. It is a layer on top. This is not meant to be the altimate cover but to keep 80+% off the dirt off to get a longer life out of the filter before having to change it. Room? I know a long deserted canyon.![]()
I never got an answer toi this..................
Will I have to purchase "bike brand specific" or do they have various styles/shapes/sizes to choose from at a parts/accessories store? Mine is oblong, kind of wierd shape and flat...air filter is located on the right side of the bike, not directly behind the carb as they once were....
Butt, I didnt mean turn around for that!I'd turn around so you CANT watch my bum...isnt that what the english call it?
A bum?
Rez...Yes, you buy the oblong legged panyhose they're at Victoria Secret![]()
the filter skins come in sizes based upon general size of the motor which relates to general sizes of the filter the motor would have, so there is a size for 80-100s, 250-500s for instance
no, most MX bikes still access under the seat
