If that is anything like fuel injected automobiles they have adaptive learning ..... And to reset that you disconnect the battery, then turn the key on and lights and anything that will store energy, Let it set 15-20 mins.... Shut everything off, Then connect the battary back. Start it and let it idle for 3 mins. and thenShall we start a list of items you need for that bike
1) get out and ride it, so you know how it feels before you start tweaking the suspension and motor. You need a good baseline and feel for the bike.
2) desmog
3) Fmf pipe or pro Moto billet end cap - this is done after desmog or gutting pipe.
3) have the bike put on computer and tuned for the FI - or take a short cut and don't ride it til you desmog it. I have been told that the computer will "self calibrate" when new. Look in your owners manual on how this works. I recall the instruction.
4) don't worry about a skid plate - you won't need it with the bike sitting in the garage
5)gearing - you may want to consider 13/48 with stock chain, 14/52 with new chain which is good for slow speed single track. I plan to switch to a 14/50 on my next set up.
6) new decals and fender arches for added HP
I'm off to work
About Item 1 - I agree on the motor, but suspension needs attention before you leave the garage.Shall we start a list of items you need for that bike
2) desmog
I'm off to work
Was that done with full riding gear on?At the minimum I need to re-gear it & lower it. With the sag set at 110mm it is a full 2 1/4 inches taller then my other bike.
That was done with street clothes both bikes back to back. Problem is 500 is so tall have a hard time just getting on it.
It will sag more then once geared up. No problem, run it.That was done with street clothes both bikes back to back. Problem is 500 is so tall have a hard time just getting on it.
