I have a 2001 klx110 and at a friends it fell over. I tried to start it a little bit later and it reved up pretty high and didn't go down. The choke wasn't on. The bike worked perfectly fine before, other than leaking oil, and never needed the choke to start even when cold. It always starts first kick. I had to ride home at the speed it reved to and it stayed the same in all three gears. When it gets to the RPMs then I can still rev it up. I took the carb apart the next day and everything was fine. I didn't check the float cuz I didn't think that would matter very much in this case. I also thought that the throttle needle thing might just be hanging in the carb so when I put it back on I tried pushing it down and it didn't move. I tried starting it again and it did the same thing. Idk if it would help to know but it fell on the right side (throttle side) and it fell pretty hard. I think it's a bad clutch but if I knew I wouldn't be asking y'all.
