carb is spotless so I need to check the reeds and compressionIf its not idling.. It needs carb cleaned or idle set.....
Have you done a compression check/checked reeds.
Whats stock jetting? whats the jetting at currently? and what premix ratio are you running?carb is spotless so I need to check the reeds and compression
I'm not sure about stock jetting it has a full pro circuit exhaust so it's jetted for it 400 main jet 32.5 pilot jet 12-82 needle on second position and we have to put fresh gas in it he just bought it and don't know what mix it has the guy said he thinks 36:1 but procircuit says use 32:1Whats stock jetting? whats the jetting at currently? and what premix ratio are you running?
mix up your own 32:1, make sure the small adjustment screw on the bottom and back of the carb is 1.5-2 turns out.I'm not sure about stock jetting it has a full pro circuit exhaust so it's jetted for it 400 main jet 32.5 pilot jet 12-82 needle on second position and we have to put fresh gas in it he just bought it and don't know what mix it has the guy said he thinks 36:1 but procircuit says use 32:1
