It's time for a new front tire. What do you guys recommend for trail riding hard packed conditions this summer?
.........why not stick with a knobby?Well for hard pack you can try the MX71 up front. I am looking at getting the 51 myself. I am running a a Pirelli Scorpion MX Hard 486 in the front on the YZ and it worked good out there and works well in the Dez.
are those dot approved and will hold up on pavement as well as be a good dirt tire?Well for hard pack you can try the MX71 up front. I am looking at getting the 51 myself. I am running a a Pirelli Scorpion MX Hard 486 in the front on the YZ and it worked good out there and works well in the Dez.
no they are not DOT approved. The Scorpion Pro is FIM and DOT approved and was rated #1 by Dirt Bike. And is used by a lot of the ISDE teams. That could be a good choice. ISDE has a wide range of terrain they run over.are those dot approved and will hold up on pavement as well as be a good dirt tire?
Softer compound makes a diff. If the side are soft and you are on hard pack, the side knobs can roll and cause the front end to wash out or the side knobs will chunk on you.Softer compound ???? Can you really tell the difference?
the 71 has more tread volume and harder tread to give you more contact on a hard surfaces. Almost like a Trials tire. The 51 is an intermediate tire with a more spaced tread in the center for better stability on straight lines. I am leaning more toward the 51 since most of the desert we ride is a more intermediate base. I run the 71 in the back because it last longer and does not chunk.What is the difference between the 71 and the 51? I never know what to get as it seems no matter where you ride you encounter hard terrain and soft terrain.![]()
....I'm not buying it!
Intermediate? Where did you get that from? I am less than beginner!You're still trying to tell us you're an intermediate rider..........
I am leaning more toward the intermediate base.
Intermediate? Where did you get that from? I am less than beginner!![]()
........see, right there!
The only problem I find with the MX51's (which I currently have) is that they tend to wear pretty quickly.Well for hard pack you can try the MX71 up front. I am looking at getting the 51 myself. I am running a a Pirelli Scorpion MX Hard 486 in the front on the YZ and it worked good out there and works well in the Dez.
