First Dirt Bike Tire Change
Dang I wish I would have been around. 99% of changing a tire is starting out small. I worked for Les Schwab for 6 years and was the commercial tire account guy. By myself I have changed everything from bike tires to Earth Mover tires. Its all about using levers and understanding leverage. 99% of the time you try to take to big of a bite. The smaller the amount of tire you try to pull over the less energy it takes. Also you want maybe a 1/2" of the bar past your rim. The less bar you have past the rim the more leverage you have. Also the other thing most people miss is if your trying to pull over the tire on say 12 o clock. You need to be pushing down on the bead at 6 o clock. You have to get that tire in the drop of the wheel. (This is the low spot where the spokes are) If you don't your trying to stretch the tire (Its not going to happen) Now going back on you have to do the same thing. Get the opposite bead in the drop of the wheel. All wheels have a drop in them. (Car wheels on offset to one side, you must take the tire off that side)(Semi wheels are either offset to one side or centered so you can take it off either)
If you have any question please feel free to ask I will help you all I can.
lol all of which i was doing bryce.. that tire i had to cut was NOT coming off. at least with the cheapie tire irons i have.
That I believe was a MOOSE tube, and you can't get them like that anymore, they are a bitch to deal with but are nice for keeping air in your tire, as for the marbles those are formed but 2 rubber objects rubbing together, so over time the tube will create those specially since it was so thick
At first I thought it may have been lead shot that crawlers use to weight down their tires in hopes of keeping from rolling....:shocked:
thanks for the info.
