I never change the filter. Make sure it is clean, oiled and greased and it is good to go.
Well I can't give a perfect answer on this but I know I'm looking into a new filter or something. I clean it after everytime we ride. (Unless there is not dust) After this last ride though I'm not happy with what I found. I used a UNI with No-toil and used lots of grease and found that after my last ride there was really fine dust getting past it.I'm going to look at getting one of the fine filters for my bike and probably ditch the No-toil.
I also use the No-Toil system, but I haven't had any problem with it. Granted I don't ride desert or in really dusty conditions.I have found the same light dust with twin air and no-toilThe no-toil is sooo easy to use I hate to ditch it but when the can is empty bye bye
thats the problem with no toil, fine dust gets thru, if you only ride prepped tracks or in the wet its ok, but if you ride in the dust it is killing your motor.
Oh that makes me so mad. I was told it was the greatest stuff since Toilet Paper. So before I rode my new bike I changed filters and oiled the filters. Then to find that I was not happy!![]()
You toiled your filters.....
I've never had a motor fail me after performing the "old school" methods of which some of you may give meand others
. Filters are cleaned with small amount of gas to cut through all the previous applied oils and grease...followed by a rinse with hot water, rung out then air dried. Once it's dry I apply a small amount of "thin" motor oil (2 stroke if it's available) by pouring it into my hand ringing my hands with it then wiping the filter and skin with it...Apply grease to the back side of the filter where it seats in the box and your done.
Do you all grease the filter before you install it. With the new cages is it necessary?
