Hello everyone,
I have a 2001 KX125 that has been causing me some problems. About a year ago now, the bike started spitting up a lot of oil from the exhaust, so I figured it needed a crank seal replacement. After removing the engine from the bike I set it all up on a table, got the proper tools for the job and disassembled and installed the new crank seals. Up until this point all was well..
When I went to put everything back together just the way it was before (following the manual) it all fit into place. Now, once the crankcases were back together, I went to turn the crank and it would barely move and was stiff in place. Same thing when I went to turn the sprocket and rod connected to the transmission on the inside of the case. Everything was just tight, as if it was torqued too hard--but this wasn't the case after checking with multiple different torque wrenches-- For several months this has been an issue and mechanics are trying to charge me $500+ to look at it, diagnose and repair, when I know this is an easy fix. So if there is anything that jumps to mind when you hear, "the trans and crank are stiff and won't move smoothly" when the cases are put back together, please let me know in comments below possible resolutions.
Things I have already checked:
-Torques are correct (using a Snap On digital torque wrench and checking with other wrenches to be sure)
-Bearings are fine
-No cracks or bends in crankcase or anything of that matter
-All pieces are properly assembled
I am still considering after all this time that it is possible that I am just making a simple mistake when I disassemble and reassemble the engine (this has happened several times). So it definitely is possible that I am forgetting something or missing something simple that could be causing this stiffness. Please any experienced mechanics or people with general kx125 or other 125 engine experience, comment below possible resolutions to this mystery!
Thank you for reading, Merry Christmas and Happy New Year!
-Bearings are fine
