Nope it sure doesnt... i thought it just required bike oil....
You'll be fine as long as it was "bike oil". Anything with a wet mesh clutch approved rating will work. And even if its not approved the clutch will just be grabby. Also that HP1 oil palmer posted is THE BEST stuff imo. Next time you change your oil i would go with that.Nope it sure doesnt... i thought it just required bike oil....
Its a good idea to ensure that it is 2 stroke rated gear oil. Preferably in 80 or 85 weight. But dont go to the automotive section at Wal Mart and by 85 weight gear oi. Thats the wrong stuff. If you have a good bike shop close to where you live go to them and ask what you should be running. Make sure they get the info out of a manual unless your comfortable with their knowledge. Other wise you could use this web site. www.motosport.com I believe they are in either MS or MO. either way there shipping will be fast because your close to their locatoin.Nope it sure doesnt... i thought it just required bike oil....
That sounds like a grabbing clutch condition usally brought on by a notched basket or inner clutch hub, or both...it could be slightly warped dics between the clutch fibers as well not allowing enough clearance and causes a grabbing clutch condition like you discribe. First step is to try to adjust your cable. if you can't get the grabbing out of it without causing too much slipping then its time pop off the clutch cover and take a look at the basket. it a pretty simple job.Well, I'll be changing it ASAP because when I drop it in first gear, she dies.
It amsoil motorcycle oil, and if I give it a little gas when I drop it to first I can get the bike rolling, I really don't know what I'm doing, but I guess I'll check the clutch...is the 10w40 a automotive oil? If so it probably has a high amount of Moly which the clutch won't like.
But that would simply make it slip, it wouldn't cause it to die, I would do as Jackson409 suggested and inspect your clutch basket/hub for notching, if its not too bad you can file it down and re-use it
