Swapped my buddies choke and float assembly on to my carb and it runs the same.
Our jetting, needle height and slide are the same.
Any ideas guys? I'm stumped
Yeah. Your carb is extremely dirty and the float isn't set properly.
OK.
Got my carb sonic cleaned and got the shop to set the float height. Ran the same slide, needle position and jets as his carb and IT STILL RUNS AWFUL.
Still lots of smoke and no power, it is no better than before.
Going to buy used carb i am sick of this thing.
When i used my buddies carb i put in my choke assembly as well as my tps.
I just don't see how our jetting could be that much different given they are practically the same bike, both with fresh top and bottom end.
But when i used his carb i used a 50 pilot and 168 main.Jetting can be different on the same exact bike on the same day with the same gas and the same oil. Just the nature of the beast.
Tried swapping TPS and Powerjet solenoid from his carb and no better.
Ive used 40, 42, 45 and 50 pilot jets and still get so much bog at 1/4 throttle,
JD jet red needle at the top position with the same results,
main jets 160, 162, 165, 168 and 170
what else could possibly be wrong? Maybe a bad o-ring in the carb? should i try a rebuild kit?
Something is wrong somewhere. Maybe try a rebuild kit.
Possibly missing o-rings?
