450F Starting issues
I have a 06 kx450f and when i first start it i have to wait a little while before i can rev or it will die out. This doesn't just happen when its cold. When ive been riding all day even when i go to start it again it will die as soon as i gas so i always have to start it then let it idle for about 2 minutes or so before i can start riding.
The size of my pilot jet is 42 and my main jet is 75. Any help will be appreciated.
Modern 4 stroke bike.... If its not starting correctly,Check the valves. If there in spec, Clean the carb..... Was never like this before... It was always clean the carb first.
Could be a valves that need to be put back into spec. Otherwise, your carb needs to be cleaned like M33 said. If that doesn't work, make sure you have some Sikk graffix - you'll be golden. :thumb:
