Thinking about going up one on the front. It's cheaper than the rear.
If they make it.... I can't do that on mine, because oem is the biggest made
id do a 48 or 47I think Joco may be right.
I may have to move to a 48 or 49 on the rear.
This is for yama_dawgg's bike...........
Is Dawgg wide open in 5th all day in the dez? If not, why change? If you want to change, I would go to a 48 in the rear. Going up 1 in the front makes 1st and 2nd taller where going down in the back will keep those gear tight but spread out 4th and 5th enough to give you better desert cruising.Too short everywhere but the nasty single track we ride here at home.
The master has spoken.Is Dawgg wide open in 5th all day in the dez? If not, why change? If you want to change, I would go to a 48 in the rear. Going up 1 in the front makes 1st and 2nd taller where going down in the back will keep those gear tight but spread out 4th and 5th enough to give you better desert cruising.
