My 08 WR 250 Manuals says use 95 octane or better. The best pump gas around here is 91 octane. Do you just run it? Do you dump octane boost in? Or something else? Let us know what you do or think about it.
some of those manuals recomend the octane for gas that is out side of the USA.. USA 91 is equivilant to 95 from other countrys... you should be fine.... if you really want to tho i know i seen those barrels of VP gas at the shops or just use booster. The good thing about the booster is it is a stabalizer tho so it helps your gas last and not go bad.
There are two octane numbers and they are derived from different measurements. One is called "research octane" and the other "motor octane." In the US we average the two and put that on the pump. In most other places they just put the research octane number on the pump. In general the two numbers differ by about 8 points. The 91 we get here will have a research of about 95 and a motor of about 87. The number in you manual is a research number so the 91 should be OK. It will be right at the limit though.
You only need to boost the octane if you have pinging. Otherwise just ride.
The weird thing is the motor number is what we should be using. It is a better representation of how we use our engines. Not good for marketing though to promote a lower number.
Not sure what your XR's are, but my 250F is 13.5:1 stock. Which is why I run 92/93, $0.20 isn't much, especially compared to 100 octane at $6 per gallon that some people run unnecessarily.I smell all these high end fuels at the track, but it doesn't seem to make them go faster or go fewer hours between expensive rebuilds! I call BS on octane unless you are over 11:1 compression!You are wasting money and just being too anal about fuel below 11: 1. Tell me I'm wrong!
