Didn't see that.Like I said James
Looking at those number again, that stock suspension is really off center. Front is for a 110 lbs guy and the rear for a 175 lbs guy.
That's really odd, my forks are pro set up for my height and weight but my forks are a little beefier than my shock. This seems really dangerous to me that the balance is so off. He will defiantly get a better feel with a .46kg/mmDidn't see that.
like I said, he needs springs either way, so start there and check wear parts, then determine whether or not you want to work on the shock.race tech is wrong, just like it was for my forks, get a factory service manual before you start blindly throwing money at the bike, it will be the best investment you can make.
Factory service manual gives you spring rates for different rider weights and riding levels?race tech is wrong, just like it was for my forks, get a factory service manual before you start blindly throwing money at the bike, it will be the best investment you can make.
Aren't you contradicting yourself? So your service manual does or doesn't have spring rates in it?nope, but it will tell you how to correctly service your forks, unlike clymer manuals, and will give you the correct spring rates
Really james?Aren't you contradicting yourself? So your service manual does or doesn't have spring rates in it?
AhhReally james?
The correct FACTORY original spring rates, meaning for the shock and the forks. I did not say the correct spring weights for your weight and riding style, however, generally 250 2t and 450's are sprung for 160 pound individuals straight off the showroom floor.
I should have got what he meant (stock rates) but I've been going on little sleep these past couple weeks.Brian is an angry lil man
I actually read it yesterday and had to re-read it 4 or 5 times to get it.I should have got what he meant (stock rates) but I've been going on little sleep these past couple weeks.
