Sort of a rebuild. Just a piston ring.
Anyway, i got it all together, put it through one heat cycle, it ran fine. I thought it was cutting out a bit, so i turned the air screw out to ~2 turns. Let it cool for about 1.5hrs, go out to start it again, it warms up good and idles fine. As soon as i hit the throttle, BOGGGGGG. Trying it again a few times, the same bog. The last time it bogs down and won't start again. I checked the plug, definitely wet.
What could be the issue? I think my jetting may be a little rich after the rebuild, it was probably jetted for the worn top end. Here are the specs, tell me what you think.
'94 CR125
FMF Fatty
175 main; 172 stock
55 pilot; 58 stock
1.5 turns out
40:1 mix
2 from the bottom on the needle
BR9EG
Thanks guys!
'94 CR125
FMF Fatty
175 main; 172 stock
55 pilot; 58 stock
1.5 turns out
40:1 mix
BR9EG
Thanks guys!
