125 big bore kx125
just picked up a 95 kx125 for cheap.it needs cases replaced,when i pulled it apart I found that the cylinder has been sleeved.Not a problem in its self but when I measured the bore I got 60mm!!The top of the piston has this stamped in it. DOOD
RPM'S
9471
59.98mm
Anyone seen this before?Still need to measure the stroke,but bore alone puts this motor at close to 160cc.Have not been able to Id the maker.Ideas?
Fix her up and ride that big bore! I think just about anyone can set up your motor with a sleeve from wiseco, and a 2T piston that fits. I doubt it was built by a race engine builder, but maybe! Either way, I'm sure you'll enjoy the tractor torque that 160cc is going to put out. :ride:
My 193cc is built off the same motor as a 125, just it was made in the factory. Mine is a 64mm. Not sure where a 60mm piston can be sourced?
