Remember. Voltage is supplied by the battery but current/ amps are drawn by the appliance. Power in watts is calculated as volts x amps. So for instance a 12 volt bulb drawing 2 amps is: 12x2=24 so it is a 24 watt bulb. so on a 12v 5ah battery it will burn for about 10 mins. This is why car batteries are quite big for only a 12 volt battery, the massive current drawn by just turning the engine would flatten a small battery, and probably still wouldn't start even then.
it means it can deliver 12v at 4 or 5 amps per hour.
one is 4 amps per hour and the other is 5 amps per hour.
quick google explains it better then i can.
I assure you the 5 AH battery will last longer and have no effect otherwise.
Amperage is a "demand" type of circuit. The battery only gives what is asked for by the load.
In this case it can run for longer because your "load" (security system) will not ask for more amperage just because it's available.![]()
It doesnt matter Rack.....
Chrissy keeps giving me the updated entry codes so I can sneak in at night and clog the toilet,![]()
It's probably the exact same battery. Someone thought that "Hey if we mark it 5 amp hours instead of 4.5 we will sell more."
As long as the voltage is the same and the new battery fits the space it should work fine.
I was going to say the same thing as Cleo. No need to thank me Rack - I'll just give you a pre-emptive, "You're Welcome"Thanks.
I was going to say the same thing as Cleo. No need to thank me Rack - I'll just give you a pre-emptive, "You're Welcome"![]()
