Hi everyone,
I have a 94 XR650L that I just recently bought not running right.
Symptoms:
Bike runs decent with the choke completely on, but after I have the bike at wide open throttle and letting off it pops out the exhaust.
If I let the bike warm up while the choke is on and then I turn off the choke, the bike will idle fine. At this point if I try to turn the throttle it will react in a very bad way (Popping out of the intake air filter and some times killing the bike).
What I've done:
I have cleaned the carb 2 times already and there was some varnish in the pilot jet that I cleaned out using a small copper wire. I also tried to clean all the passages the best that I could with the copper wire.
I am running the stock jets, a 152 main jet and a 50s pilot jet. I've also been trying to tune it up using the air mixture screw but with little success.
Any thoughts on what i could do to fix this?
I was thinking I might boil the carb in vinegar to see if I could clear up the passages a little better.
Thanks,
Akamph
Symptoms:
What I've done:
Thanks,
Akamph
