Forums
New posts
Search forums
Members
Current visitors
New profile posts
Search profile posts
What's new
New posts
New profile posts
Latest activity
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Everything Dirt Bike
Make / Model Specific
Kawasaki
2005 KX250F Cam Chain Timing
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Tylluuh" data-source="post: 232983" data-attributes="member: 7035"><p>Find the pair of marks on your flywheel, both right next to each other.</p><p>If reading left from right, you'll want the second mark. </p><p> | | <----this one</p><p>(Note: when finding top dead center, your piston may fall back down if not held at TDC. This was the case for me, and I had to find TDC and keep it still while I worked on the timing chain and cams. The weight of the piston + gravity will have the piston fall back down the cylinder, resulting in the flywheel marks not lining up with the "flywheel timing viewing window" marks.)</p></blockquote><p></p>
[QUOTE="Tylluuh, post: 232983, member: 7035"] Find the pair of marks on your flywheel, both right next to each other. If reading left from right, you'll want the second mark. | | <----this one (Note: when finding top dead center, your piston may fall back down if not held at TDC. This was the case for me, and I had to find TDC and keep it still while I worked on the timing chain and cams. The weight of the piston + gravity will have the piston fall back down the cylinder, resulting in the flywheel marks not lining up with the "flywheel timing viewing window" marks.) [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
Kawasaki
