I like the all black seat personally!Sure you go ahead and take off two triple clamps without at least asking first.
Swapped the seat, levers, and engine plugs. Looks like the coolant hoses might work as well.
Because he has aftermarket parts on the 05 that are better than bothwhy would you swap the parts? wouldnt the parts on the 08 be better?
and i think that you can check if the part are the same by going to a website that sells oem parts (motorcycle superstore, bike bandit) and checking if they have the same part number
Thanks D-K , I assumed as much on the triple clamps, being a new frame and all. (Jos, this is why I didn't just try it )Hey James! The 05 triple clamps will not fit. The aluminum frame has a different steering stop.
Engine plugs will fit, but only up to -10. In 2011 the 250 got F.I. and the big plug is now the same as on the 450 (which is bigger).
Water pump will fit all years.
More questions?
Are you recovered from the gnarly crash you had? Maybe you have had a few since? Lol...
I need more info than that, for example the actual error message. Otherwise it's like pissing in the dark............P.S. 3 error reports in a row trying to post this... page didnt sit at all
Good to hear, yes 2012 should be epic to say the least. We are a gang of 15 Swedes going to Vegas in May for the SX final! Should be nothing short of total awesomeness.Yup I was pretty much recovered from that by last spring. However I did get my other shoulder fixed this winter. This should be an epic year; new bike and the body as close to 100% as its ever been.
How about you, your leg finally doing better?
