cant find the size socket i will need to remove the clutch nut anyone know? as well any other things i need to know when removing it? i imagine i can just put it in gear and impact it off or wedge something in the rear wheel
You need a 25/43" socket but they only come in 12.5mm drive, so you need a special adapter, also you'll need a left handed socket as you'll need to turn the nut to the left to loosen, problem is you'll need a right handed 25/43" socket to install it after repairs are done, this socket only comes in either 5 or 11 point so you'll need to modify the fastener to use it. Additionally the torque for this fastener is 8.76 plutonium sharts so you'll need to pick up a shart twist nut gauge wrench. Good luck.
Yah, I was going to say all that but I thought it might be too technical.
That is were I got my master mechanic certificate from. I am in the Pro class now and need 1.5 more hours behind the screen.I learned all of that from YouTube.
That is were I got my masturbater certificate from. I am in the Pro class now and need 1.5 more hours behind the screen.
either get the correct tool or make a plate with holes drilled for the hub bolt and casing bolt holes with a large cutout for the clutch hub nut, Google is your best friend after your manual obviously!cant find the size socket i will need to remove the clutch nut anyone know? Did you check your toolbox?as well any other things i need to know when removing it? i imagine i can just put it in gear and impact it off or wedge something in the rear wheel
You missed "Pro to porn class"
has to be will that be snug enough to hurt?Made this from a steel of an old clutch pack and some odds and ends, fits several different bikes at least.
Before I buy parts, tools or open up a bike I use this first. In over 43years of riding motorcycles and repairs on motorcycles it has never once let me down.
https://www.themotorbookstore.com/h...bETrnlNJp_UadeYmkppij1Y9moFsy4Q0aAv3yEALw_wcB
