my ttr 225 is running rough--popping on decel, takes forever to start and warm up, only starts on choke , and then after it warms enough to take the choke off, it hesitates under accel really bad til it gets good and hot. any suggestions?
Thumper Talkwhile you have your carb off I suggest reading TT's(GASP) jetting thread on the ttr. they are incredibly lean stock and benefit greatly from bigger jets.
that was a fun mod.been looking at these bikes to replace the two little ones I just sold and I seen alot of people talking about they are jetted super lean from factory, to put bigger jets in them and they run much better. Ofcourse changing the jetting and plastics to orange like CDA did makes them run even better
where is that upgrade thread
hi. i have a 2002 yamaha ttr 225 starts and runs fine until it warms up. about 20 miles, then it acts like it is starving for fuel. spark is good compression is 150lbs,, carb has been cleaned and cleaned again, i have increased the jet sizes both mains and pilot. you mention open the air box, and also adding a 3/8s washer to exhaust end cap? not sure i understand.. could you explain that in more detail? thanks i am frustrated love the bike for the first 20 miles hahathat was a fun mod.
Just open the air box, add a 3/8s washer spacer to the exhaust end cap, bump the main and pilot one size up and you'll be good to go.
Check your petcock filter and the tank vent ....get rid of that fancy looking tank vent ....hi. i have a 2002 yamaha ttr 225 starts and runs fine until it warms up. about 20 miles, then it acts like it is starving for fuel. spark is good compression is 150lbs,, carb has been cleaned and cleaned again, i have increased the jet sizes both mains and pilot. you mention open the air box, and also adding a 3/8s washer to exhaust end cap? not sure i understand.. could you explain that in more detail? thanks i am frustrated love the bike for the first 20 miles haha
