Forums
New posts
Search forums
Members
Current visitors
New profile posts
Search profile posts
What's new
New posts
New profile posts
Latest activity
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Everything Dirt Bike
Make / Model Specific
Yamaha
2008 yz250f weird problem need help
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="SRAD97750" data-source="post: 232620" data-attributes="member: 425"><p>Howdy.</p><p>I suspect the bottom end/crank bearings are the problem.</p><p>-The condition and quantitiy of oil has varied wildly while in use.</p><p>-Broken engine parts in the oil.</p><p>-The engine locking up and unlocking.</p><p></p><p>These signs following an oil issue is usually not good.</p><p><strong>Some bearing is giving you trouble and it'll probably be discolored</strong>.</p><p></p><p>I'd take the top end off, and get the crank spinning freely from the clutch and see if it binds at all.</p><p>Does the clutch shaft spin freely?</p><p>Main clutch shaft bearing also would be good to inspect.</p><p>-BIG DAN<img src="https://www.dirtbikeaddicts.com/static/images/smilies/thumb.gif" class="smilie" loading="lazy" alt=":thumb:" title="Thumb :thumb:" data-shortname=":thumb:" /></p></blockquote><p></p>
[QUOTE="SRAD97750, post: 232620, member: 425"] Howdy. I suspect the bottom end/crank bearings are the problem. -The condition and quantitiy of oil has varied wildly while in use. -Broken engine parts in the oil. -The engine locking up and unlocking. These signs following an oil issue is usually not good. [B]Some bearing is giving you trouble and it'll probably be discolored[/B]. I'd take the top end off, and get the crank spinning freely from the clutch and see if it binds at all. Does the clutch shaft spin freely? Main clutch shaft bearing also would be good to inspect. -BIG DAN:thumb: [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
Yamaha
