Forums
New posts
Search forums
Members
Current visitors
New profile posts
Search profile posts
What's new
New posts
New profile posts
Latest activity
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Everything Dirt Bike
Make / Model Specific
Suzuki
1995 Rm250 Transmission problem
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ossagp" data-source="post: 180145" data-attributes="member: 1650"><p>bearings from the right source are not that expensive so replacing the ones you have to split the case to get to are about the minimum. that bearing has the most load on it than the others will especially when in first gear. it is also the one most likely to have dirt forced into it past the seal. and it very well could be the original. welcome to the world of 20 year old rides!!</p></blockquote><p></p>
[QUOTE="ossagp, post: 180145, member: 1650"] bearings from the right source are not that expensive so replacing the ones you have to split the case to get to are about the minimum. that bearing has the most load on it than the others will especially when in first gear. it is also the one most likely to have dirt forced into it past the seal. and it very well could be the original. welcome to the world of 20 year old rides!! [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
Suzuki
