125 yz 125 2000 gearbox oil ?
Hi everyone, i have 2 quart of motul gear 300 sae 75w90 it is good for my 2 stroke gearbox or i need to go to local dealer and say i want my refund and buy another one
Yes, that is a good one. Most oils will work great in a 2T transmission as long as they don't have 'friction modifiers' which CAN cause clutch slippage in some instances.
I personally prefer ATF for my 2Ts, but just about anything will work! -BIG DAN:thumb:
hi thanks for your reply but i found this oil Specially designed for gear boxes without a wet clutch or hypoid rear axles can it be good ? because i have wet clutch ?
The spec sheet states for use in all mechanical transmissions. Does not mention a wet-clutch on this sheet.
https://www.motul.com/system/product_descriptions/technical_data_sheets/106/original/Gear 300 75W90_GB.pdf?1290086772
-BIG DAN :thumb:
Note: there is a Motul 300'LS' type which has friction modifiers for limited slip differentials. :naughty:
-BIG DAN :thumb:
HI thanks for the spec sheet but it's strange he dont talk about it because i found this on a seller site like amazon or gomoto here the link http://www.gomoto.ca/en/parts-and-a...0-gearbox-75w90-oil-for-big-twin-1l-18-620092
I prefer hemp oil when your done riding you can get high as the bejesus
2011 sport lsr mid travel 28 Itp baja cross all the way around with some elkas
The gears and bearings live with just about any kind of oil. If you like the way it shifts, everything else will be happy. Atf or about any I'd the hd hydro oils work really well.
