Why is there a hole?
Just noticed it... Did a cap fall off? What can I do to fix it? Here's a picture:
It blows air out. Wine cork should do the trick?
If you are not planning on putting an electric starter back on the bike (wish you luck in even finding one) drill a hole in the center of the housing where the cork fits and run a screw through it and into the cork. Or if you want to spend some money.... Find expansion plug (like for a little boat) and stick it in, tighten in up, and rip that Chinese bike around like you stole it!
You can also look for an expandable freeze plug from and auto parts shop to fit the hole. Remember, what ever you put in that hole has to hold up to some build up of crank case pressures.
Paw Paw
I easily found a starter for a chinese quad I acquired. In my case it was necessary because it doesn't have a kick start. But if you'd like help trying to find one you could provide the make and model.
