Hi everyone.
Went riding today, ended up having to ride through some water ruts. Didn't realise how deep 1 of them was until I actually rode through it. It was almost to the top of my front wheel.
Anyway, the bike started blowing white smoke/steam, the oil became all bubbly and thin and wattery(wasn't milky but just looked very thin like it was water based), as well as the bike not wanting to start back up for a while(out of the water) and the inside of the muffler was all wet/wattery too.
(Its not a blown head gasket as the bike just had a rebuild and I also didn't lose any coolant).
Anyway, I brought it home, took the air filter out and checked inside the air box and found a little puddle of wet brown water inside the air box, just below the carby intake boot.
EVERYTHING else around the filter, including the filter itself was clean as a whistle, dry and still had air filter oil on it and the sealing surface where the filter seals against was not muddy or wet at all, just had rim grease on it, as it usually does....so the water didn't get in externally from outside the air box.
It got sucked up through the carby vent hoses that hang out the bottom of the bike(too much water going in at a fast rate), because that's the only other way it could've made its way into my air box, and through my motor then out my exhaust.
The bike did end up starting back up and running in the end, it wasn't hydraulic locked or anything, so I rode it back to the car even if the oil had a bit of water in it, and it wasn't too much water, but was enough to get into my air box.
Ive already done a few oil drains to get all, if not most the water out but i'm just wondering, what's the best way to re-route the carby vent hoses?? I have read the Dave Hopkins Carb Setup 101 method, wondering if there's other methods people use to re-route em? his method still has 1 hose facing below the bike.
It's a KTM 450 EXC 2004 model.
