This has kept me busy for quite awhile:
Building it and, now, fine-tuning it.
2013 YZ-250R
2013 WR-450F Headlight Upper Bushings (2)
2012 YZ-250R Rear Fender (Blue instead of White)
2010 YZ-450F 5XC- Footpegs (Lower, Wider & Stronger)
2007 WR-450F Headlight Assembly
2007 WR-450F Left-Side Headlight Brackets (2) (Modified one to work on right side.)
2007 WR-450F Headlight Lower Grommets (2)
2007 WR-450F Tail Light Assembly
2007 WR-450F Front Brake Line Clamp
2007 WR-450F Front Brake Line Guides (Upper & Lower) & Bushing
2007 WR-450F 18" Rear Wheel & Tire
2002 WR-426F Wide-Ratio, 5-Speed Transmission
1997 WR-250Z Petcock (with Reserve)
Eric Gorr 300 (295cc) Big Bore with "Mo' Better" Porting
Boyeson RAD Valve
Scary Fast Power Now
TwinAir Air Filter
FMF Gold Series Fatty Pipe
FMF Q-Stealth Spark Arrestor Silencer
Steahly Flywheel Weight (11 oz - not yet installed)
GPR V4 Under-Bar Steering Stabilizer
Race Tech Fork & Shock Springs
Motion Pro Micro Fork Bleeders
Galfer Stainless Steel Front Brake Line (For a 2007 WR-450F)
Tusk Rim Locks
Ricochet Offroad Aluminum Skid Plate
System Tech Footpeg Lowering Brackets
Moose Kickstand
Tusk Big Bar Aluminum Handguards
Maier Extra Coverage Handguard Covers
G2 Aluminum Throttle Tube & Cams
Renthal Grip Donuts
Baja Designs Ignition Key Switch & Mount
S&S Headlight & Horn Switch
S&S Rear Brake Light Switch
Tusk 12v Horn
DoubleTake Rearview Mirror
Trail Tech Vapor Speedometer
IMS 3.2 Gallon Gas Tank
Tusk Aluminum Gas Cap
Free Flo Vent Hose
Guts Tall Soft Seat Foam and Gripper Cover
Yamaha Blue Anodized Aluminum Oil Cap
ebay Aluminum License Plate Holder (For 2007 WR-450)
Fastenal M6 x 60mm Bolts for Tail Light (3)
DecalWorks Custom Graphics
Tusk Front Fender Pack with Tire Irons & Spare Front Tube
Moose Rear Fender Pack
Ground the steering stops down to increase turning angle
Street Licensed
2013 YZ-250R
Boyeson RAD Valve
TwinAir Air Filter
Tusk Rim Locks
Moose Kickstand
Renthal Grip Donuts
Tusk 12v Horn
Free Flo Vent Hose
Street Licensed
2013 YZ-250R
Boyeson RAD Valve
TwinAir Air Filter
Tusk Rim Locks
Moose Kickstand
Renthal Grip Donuts
Tusk 12v Horn
Free Flo Vent Hose
Street Licensed
But, I didnt see the sink?! Where is the sink?
That is one heck of a bike!
I'd be afraid to crash it.
Send it to me and I'll do my CDA test/write up on it.
Tires? What tires are you running????
Wow very nice that should be as good if not better then a orange 300 I think I would take your setup for sure GOOD WORK!!!!
I'll keep my eye out for it.It's in the mail.
No Rekluse?
Never tried one. I'd like to ride someone else's before buying one.
