That ain't a gas tank mate, this is a gas tank
Friggin Aussies, always going to the extreme, 12 gallon fuel tank.
Try picking it up after you fall.:smirk:
I'm thinking the shear weight of that tank would cause it to crack open if dropped, spilling 12 gallons of fuel onto a hot exhaust pipe, resulting in a heck of a fireball. So picking it up will be the least of your problems.
This thing is a bit of an over kill.
:shocked: Damn that'd be a lot of weight.
That is an under statement.
:shocked: ..... How do you even hold that up...
Not very easily, especially on the side of a hill. :shocked:
I would need some friends for this attempt.
Fuuuugly!!!
I agree. :thumb:
:shocked: that thing is huge!
That is what she said. :devil:
Is there a fuel pump hooked up to get the 10 gallons below the carb up there? Crank up the compression dampers.
For sure.
Run would be a good idea.
With 73lbs of gas, I would wonder how the handling/suspension would change full vs empty...
Quite a drastic change I would think.
one of the few places a tank like that is actually needed. at least i hope its not just so he can skip that gas stop here and there.
