What is the easiest way to start this big bore monster I am 140 lbs kicking is kicking ma azz any tips? Thanks for looking and your time
1986 Yamaha YZ490Hahahahaha!!!
Please tell me it's a Maico 490
Right on Thanx brotha kicking my ass1986 Yamaha YZ490
So, I like to prime the engine with a few slow moves through the travel of the kick lever.
Then i apply a hefty pressure to the lever and get i to just pop past compression and onto top dead center. This motor makes an obvious noise and movement when it arrives in the tdc groove.
Then, lever to the top and kick one time as hard as possible.
If no fire, get it back to tdc past the compression and try again.
The motor should spin 4-5 times per one kick if you set the engine past compression.
Here I am starting the motor in question.
https://www.youtube.com/watch?v=Tz6JnwofnlA
-BIG DAN
Goddam you kicking like Bruce leeSo, I like to prime the engine with a few slow moves through the travel of the kick lever.
-BIG DAN
Tom are you a girlie? Most guys I know will gladly tell you they already have a third legHehe or grow a third leg yeah guess I gonna need go grocery store little more often
Its more like a tentacle than a leg and thanxTom are you a girlie? Most guys I know will gladly tell you they already have a third leg
Welcome to DBA btw
