On the cylinder do I need part 15 or 24? And which parts should I order for the water pump.
Ok which part number is actually the head gasketPart 2 thru 8 and #10 for the water pump.
Parts 24, 15 and 36 if you remove the cylinder.
Which part number is that and yes I doIt's the one between the head and cylinder......
Do you have a service manual?
Ok thanks and is this something I should have someone do if I've never been in an engineUmmmm 15..... See above
I'm from oil city Franklin area but is it necessary to replace all that in the water pump or can I just replace the seal. Maybe you can tell me which one I have to replace for the problem I'm having. My bike keeps leaking coolant out of the overflow after I ride it for a while. I already tried replacing the radiator cap, but it didn't help. My oil does look milky but someone told me that could be because I just put a new clutch in it.What part of Pennsylvania are you from.
