How do you take dents out of a 2stroke pipe?
Do you have a big freezer? If so you can put some water in the pipe and stick it in the freezer. When the water freezes in the dented area it forces the dent out. Or you can plug one end and take a heat torch to the dented area while you fill the pipe with air compressor from the other end.
Freezer method is probably the safest.
I recommend if you are going to torch it and pressurize it, fill the pipe with water 95%, then apply compressed air. The less compressed gasses in the pipe, the safer it will be.
Water does not compress, so it has no energy if the pipe were to burst.
Filled only with gas, the release of pressure would be violent. -BIG DAN:thumb:
