I'd suggest putting it in 5th gear, have somebody hold the rear brake, and hit it with the biggest impact gun you have.
Wouldn't 1st gear be better
5th will give more resistance. Ever try taking off in 5th gear from a stand still?Wouldn't 1st gear be better
Actually from my experience of breaking bolts loose, 1st is better. Bump start your bike, it will be easier to do in 5th than first. Just my 2 cents5th will give more resistance. Ever try taking off in 5th gear from a stand still?
5th will allow the engine to turn over easier.... Ever tried to push the bike in 1st gear compared to 5th...5th will give more resistance. Ever try taking off in 5th gear from a stand still?
After discussing this with Big Dan, trying to rotate the countershaft with an impact and bump starting a bike are to different things (ratios).5th will allow the engine to turn over easier.... Ever tried to push the bike in 1st gear compared to 5th...
Exactly, however if you were to start the engine you could drive off in 1st, but not 5th.This is why when you drive a manual transmission automobile... You put it in 1st.. Not 5th....If you put it in 5th... A normal person could push the vehicle and it would turn the engine over... Put if you put it in 1st... It the gear ratio/to compression ratio is much lower...
1st gear for parking your truck.And.... What is answer... 5th or 1st...
I still say first
Helps if you think about where the power is coming from, that's why you can't compare bump starting with taking a nut off.I get what you are saying... But i will have to think about it for awhile
Are you referring to 5th having more resistance in taking a nut off? It's basically the same as riding the bike, you take off in 1st as it has the least resistance right?Yeah.. Thats what i was thinking... But i can't get it into my head that 5th is better than 1st...
PS... I just put dip in.. (Redneck's thinking cap)
