About a year ago i was riding my RM250 it was running awesome up until when i got near camp, luckily, it stalled out. I tried kicking it over and there was 0 compression what so ever would could cause this??? thanks
k cool thanks and I don't think it ever had a time for top end because it was sitting in my uncle garage for years. He bought it in 1986-87 I think and he never used it. Then gave it to me and my dad and I looked over the carb cleaned that out and it ran fine for a while. Thanks again thoughProbably time for a over haul... Could be a base or head gasket.
When was the last time for a top end?
Will need to check the cylinder, also. If you burnt a piston doown more than likely its going to need the cylinder replated.
ok awesome thank you so much!!!The older ones might have a steel liner in the cylinder.. (I'm not positive, but someone on here will be able to tell you for sure or not.) ....
thanks! will do appreciate ityep you could have burnt a hole right in the top of the piston. First thing I would do is pop off the pipe and have look. you can get a good look at the top of the piston and check some of the cylinder wall. If you can't see anything wrong, then do a compression check with a gauge.
Then report back what you find. We lurvs this kinda chit good luck, hope its just a stuck ring or something simple.
Exactly Jess Or, you can just sell it to my son so we can put it in my shed and I have another project that never gets completed........yep you could have burnt a hole right in the top of the piston. First thing I would do is pop off the pipe and have look. you can get a good look at the top of the piston and check some of the cylinder wall. If you can't see anything wrong, then do a compression check with a gauge.
You sound like meExactly Jess Or, you can just sell it to my son so we can put it in my shed and I have another project that never gets completed........
Yep - we still have a '98 XR 70 that was gonna be the most Badarse Pit-bike in the world...in the world I tell ya..You sound like me
