Hello Again Sirs,
I finally got around to Separating the Crankcases on my 1986 Honda CR250R, I left off with a Jammed Lifter Rod (a.k.a. Pushrod). You might recall. I split the Cases and there it was a Groove in the end of the Lifter Rod (Mushroomed ?). See Photo. This is the Opposite side of the Main Shaft Clutch / Lifter lever. Could the cause of such a Groove in the Rod have been from a Lifter lever Bearing (In the Flywheel Housing). How Hard is it too replace this Bearing.
As the Title says I have a lot of Questions, you guys are the only ones I can talk Bikes with. Thank you it's really appreciated.
