Other Carburator question
when fuel is off, carburetor does not leak. when gas is on, fuel drains from the overflow tube facing the ground. i dont not know much about carburetors. im thinking it is a problem with the float. Need some input on how to solve this problem, thankyou
Did it just start happening?
If it's just stuck from after storage, tap the bowel with the back of a screwdriver handle, or crash bike to left and right banging it on the ground.
Otherwise, you'll need to remove the carb, reset or rebuild carb and set float level per manual.
