how do i tell how big the Athena cylinder is that i got ? I need a piston and i dont know if its 54mm or if its slightly bigger or smaller? can anybody help? thanks it would be much appreciated.
How so? There's no replacement for displacement.i looked at the athena big bore kits because i once wanted one and i didnt see one positive thing about them every one that got one said it was a huge dissapointment
How so? There's no replacement for displacement.![]()
idk they said they expected way more power because most users said they barley felt a power increase
big bores kits alone will just create more grunt down low for the most part. If you want more hp, you should mess with compression, cams(4t), porting/polishing, pipe combos![]()
Then you'd be just as fast (or slow) as you're now, instead spend that on training/practice.if only i had 10 grand to spend on my baby![]()
carb!
not if i got suspension and port and polished like everything and got rid of mycarb!
It doesnt matter how fast the bike is... its all about the rider.not if i got suspension and port and polished like everything and got rid of mycarb!
