all puddles come from somewhere, find the wet spot on the bike.
thats how you find the sweet spot on a big girl.Floyd says to roll it in flour.
Thanks I've been hearing it could be an o-ring
Yeah I know ehI am trying to remember how we did things before the "net".
I've heard rumors that our ancestors spent a great deal of time outside.I am trying to remember how we did things before the "net".
What is this plug for anywayspull that plug out, there should be an o ring
it lets you see the flywheel, the large one lets you rotate the crank and through the small hole you will see marks indicating what position the crank/piston is at, top dead center for example, which it needs to be at in order to check the valves and time the engine.What is this plug for anyways
Thanks, I do need to shim the valves also. My local Kawasaki dealer should sell o rings eh?it lets you see the flywheel, the large one lets you rotate the crank and through the small hole you will see marks indicating what position the crank/piston is at, top dead center for example, which it needs to be at in order to check the valves and time the engine.
