2004 Honda cbr125 4T fuel in oil?
If you have fuel in your oil, check the vacuum petcock (if applicable.) If the diaphram tears, fuel fills the crankcase.
The best way to check for this is to pull the vacuum line off and check for fluid in the hose. Should be dry as a bone.
Be sure to completely drain and refill the oil after you find the source.- BIG DAN:thumb:
So when you crank her case Her diaphram tore?.... I think I saw a film like that once....
