These past few weeks I've been rebuilding a '85 YZ250. When I got the bike to a point that I could start it I tried kick starting it for at least a half hour(With and without the choke) When I finally gave up trying to start it I took the carb off and took it apart and cleaned it to the point it looked new(inside and out), I put it all back together and made another attempt to start it, Still nothing! I was starting to worry that there was some other problem. I then tried push starting it After six or seven attempts It finally started but died after I let off the throttle. Pushed the bike back to my house and called my dad, He told me to Make a couple adjustments on the carb(something like the air/fuel mixture screw and the idle screw) Made those adjustments and tried kicking it twice wouldn't start, I push started it a couple more times and it finally started again. I started heading back to my house and the bike acted like the clutch was slightly disengaging. It would drive fine with the throttle barley cracked opened. anymore throttle than that the bike wouldn't go any faster the engine would rev a little bit. I parked the bike for about five minutes went out and tried kick starting it. It fired up on the second or third kick, It ran for about ten seconds and died. What can I do to keep it from dying?? (It's getting gas, Has a new spark plug/getting spark) The gas/oil mix is 32:1 right now.(Side note it's a 2 stroke) The bike has all the plastics aside from the side plastics where can I find the side plastics?? Are older 2 strokes normally this hard to start after a rebuild? I have a '82 YZ80 i rebuilt a while ago and it wouldn't start when i tried to kick start it.. I finally gave up and tried push starting it on the second attempt it started.
Any Help will be greatly appreciated!! Thank you in advance for the help
